CPanel Looklike GUI
Hello
perhaps cpanel GUI’s looklike will make cyberpanel have a plus point
cPanel GUI sucks to be honest. Its very age old design and not mobile friendly too.
ok then… i think cyberpanel is cyberpanel. my customer must understand and i should get more technique to make new customer comfort with cyberpanel gui
If you are using the latest cyberpanel version, there is a new menu option “Design”. Make use of it and you can change the overall look of cyberpanel using CSS in it. Try it.
noted. i will try to experiment on it
thank you
