Just want to make sure if this is the correct way to access say: Openlitespeed, Cyberpanel or a portainer server. At least it worked for CP & OLS where I can access it via cp.domain.com and
ols.domain.com respectively.
Let’s assume the subdomains for all three services are as follows:
I would edit the /usr/local/lsws/conf/httpd_config.conf
file and add the following code. BTW the 127.0.0.01 worked for me, but e,g. cp.domain.com in the httpd_config.conf file did not.
extprocessor cyberpanel {
type proxy
address https://127.0.0.01:8443
maxConns 100
pcKeepAliveTimeout 60
initTimeout 60
retryTimeout 0
respBuffer 0
extprocessor ols {
type proxy
address https://127.0.0.01:7080
maxConns 100
initTimeout 60
retryTimeout 0
respBuffer 0
extprocessor portainer {
type proxy
address https://127.0.0.01:9443
maxConns 100
initTimeout 60
retryTimeout 0
respBuffer 0
Then for each domain created via CP UI, I would add the following rewrite rule
REWRITERULE ^(.*)$ HTTP://cyberpanel/$1 [P]
REWRITERULE ^(.*)$ HTTP://ols/$1 [P]
REWRITERULE ^(.*)$ HTTP://portainer/$1 [P]
Small update:
What is strange is that if I used cp.domain.com:8443
& ols.domain.com:7080
in the httpd_config.conf file, CP & OLS are NOT accessible. However with 127.0.0.1:XXXX
they are.
But with portinainer I have to use portainer.domain.com:9443
for it to work without the port number? 127.0.0.1:9443
will NOT work without port
Anyone have an idea why that is? That makes no sense to me…Or are CP & OLS setup differently in terms of networking and such?
