I set it up very easily.
- Ensure Redis is up and running
- Enable Redis via the WordPress plugin, only setting I had to change was password because I use requirepass
Additionally, I’d recommend these settings in redis.conf:
maxmemory 100mb
maxmemory-policy allkeys-lru
maxmemory-samples 10
appendonly yes
and disable snapshotting, comment out the lines beginning with “save” to do this, for example,
#save 900 1
#save 300 10
#save 60 10000
I’d also add vm.overcommit_memory = 1 to /etc/sysctl.conf.
Also disable transparent huge pages,
echo never > /sys/kernel/mm/transparent_hugepage/enabled
