I have installed Cyberpanel on Almalinux 8.6. Everything is working fine except phpmyadmin is not working. When I try to open phpmyadmin, it shows an error “Composer detected issues in your platform: Your Composer dependencies require the following PHP extensions to be installed: mysqli” Please give me a solution to this.
Try this solution:
Can you please share any other method or solution? This one doesn’t solve it.
So, have you installed the missing mysqli extension?
Yes, I installed the MySQL extension and JSON, but the problem remains.
Still getting this error “Composer detected issues in your platform: Your Composer dependencies require the following PHP extensions to be installed: json” please help to solve.
So, installed the json extension?
Yes, i have installed json
I have experienced the same issue. Unfortunately, this issues are specific to Almalinux.
When I have reconfigured my server using Ubuntu, everything worked fine.
