I just setup my server with AlmaLinux 8, running yum update -y and installing CyberPanel, then installed CloudLinux after CyberPanel as per the docs. Root credentials are not working at the page on port 9000. Continued on to install Imunify360 per the docs, root credentials are not working at the imunify page either. Tested these same credentials in a Putty TTL terminal and it logs me in just fine. I do not have SSL setup yet, could it be giving me the boot since SSL is not active yet?
