CyberPanel Community
CentOS7 Creating website stuck on Starting Creation
FK
Faheem Kiani #1
I am trying to create the Website in Cyberpanel using VPS but I am stuck in the website creation process.
Can you check this issue plz?
jo
josephgodwinke #2
Welcome @faheemkiani Happy you are here
Which operating system are you running ?
Did you try to run the upgrade script ?
FK
Faheem Kiani #3
I am using CentOS 7 64bit with CyberPanel
I did not try any script
FK
Faheem Kiani #5
but i want to use it
if downgrade then it will help or not?
How to downgrade it?
jo
josephgodwinke #6
I recommend you swtich to AlmaLinux 8.3 - 8.5 or Ubuntu 20.04. They are the most stable os currently.
JQ
Juan Quinta #7
Hello, who is your hosting provider? Hostinger perhaps?
I have the same with them and the same thing happened to me! When I read the warning, what I did is change the OS from the hostinger panel and I reinstalled the other operating system, I left it working for about 6 hours and then I returned to Centos 7 with Cyberpanel and that’s it, I was left as I wanted
Since it is no longer a really “clean” install on the server
I hope it works for you!
Greetings
FK
Faheem Kiani #8
The problem is solved.
I changed the hostname using Terminal than issue is solved.
Thanks for help and guidance
