I am facing difficulties with ssl renewal and when I tried different solution I lost my website. Now nothing is showing up there,
can you guys please help me.
Centos 7 ERR_CONNECTION_REFUSED
website is bpmc.agency
Happy New Year @Bhanup
See this Failed to obtain SSL, issuing self-signed SSL for: mydomain - #2 by josephgodwinke if it helps
but how to get my website back
Is this a fresh installation ? Which server os ?
no it is not fresh installation. it is centos 7
I upgraded cyberpanel yesterday
what command I should use to reboot the server
sudo reboot
it says remote side unexpectedly closed network
Well this usually a vague error from putty but most of the time its caused by a server which is not online. Do you have access to your server manager? Restart your server from there
I tried, but still not getting it back
I tried to add additional ssl on the website but later I deleted it, I think this caused the problem
I tried additional ssl, because default ssl not working from some days and I tried everything. but still problem not solved.
and just because ssl is not working my campaign failed because all of the emails gone in spam, just because of not having ssl cerfitified link
Contact your server provider to confirm that your server is up
