Whenever I click on send, I get the error “can’t send message” https://i.imgur.com/8jyRmxM.png
Please help
Please help
attach your server with platform request for email debuger and reset,
Just enable API access within cyberpanel (under menu “users”), for admin.
Then visit cyberpanel cloud
connect your server there.
Select the email debugger option there and reset the mailserver which will fix your issues.
have you set this :
Please raise a ticket there requesting to enable the email debugger for your account and it will be enabled. Then you can reset your mailserver.
