Sends a letter to another postal service (yandex), but says that there is no signature, although SSL is set, in any case, it works, letters come. Outlook also works, but goes to spam, but google…
P.S. Everything worked until the panel was upgraded to the latest version.
I contacted the support of my server provider. They said that Google’s answer points to the ip6 of their mail relay. They told me to try disabling ip6. I’ve done
I don’t understand why SPF and DKIM fail the test, the panel automatically generates them. There were no problems before the panel upgrade.
Google error with IP6 - IP of relay my hoster server. I’ve added, itsn’t work
Mail tester says about IP4 of relay my hoster. I’ve added, waiting for update records.
But I don’t know what to do with DKIM, why is it invalid. I found a theory about extra quotes on this forum, removed them, I’ll wait for the update and check.
why are my records not changing for SPF and DKIM records?
Why does the mail tester see them as invalid if your panel generates them automatically.
Everything stopped working for me after upgrading the panel, why after the upgrade there are always bugs and errors, judging by the topics on the forum?
