Apr 6 17:42:42 localhost dovecot: pop3-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:42:43 localhost dovecot: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol, session=<xK+Ckaj4m8hnMTI1>
Apr 6 17:42:43 localhost dovecot: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:0A00018C:SSL routines::version too low (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A00018C:SSL routines::version too low, session=
Apr 6 17:42:46 localhost dovecot: pop3-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:42:58 localhost dovecot: pop3-login: Disconnected: Aborted login by logging out (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:43:01 localhost dovecot: imap-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:43:25 localhost dovecot: imap-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=<838DlKj4q8hnMTI1>
Apr 6 17:43:25 localhost dovecot: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol, session=
Apr 6 17:43:25 localhost dovecot: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:0A00018C:SSL routines::version too low (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A00018C:SSL routines::version too low, session=
Apr 6 17:43:28 localhost dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:43:39 localhost postfix/smtpd[23658]: connect from unknown[103.49.50.53]
Apr 6 17:43:39 localhost postfix/smtpd[23658]: disconnect from unknown[103.49.50.53] ehlo=1 quit=1 commands=2
Apr 6 17:43:42 localhost dovecot: pop3-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=<M/0Vlaj4u8hnMTI1>
Apr 6 17:43:43 localhost dovecot: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol, session=
Apr 6 17:43:43 localhost dovecot: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol, session=
Apr 6 17:43:43 localhost dovecot: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:0A00018C:SSL routines::version too low (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A00018C:SSL routines::version too low, session=
Apr 6 17:43:46 localhost dovecot: pop3-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=<1GFElaj4wMhnMTI1>
Apr 6 17:43:58 localhost dovecot: pop3-login: Disconnected: Aborted login by logging out (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=<0Q37laj4x8hnMTI1>
Apr 6 17:44:01 localhost dovecot: imap-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:44:25 localhost dovecot: imap-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:44:25 localhost dovecot: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol, session=
Apr 6 17:44:25 localhost dovecot: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:0A00018C:SSL routines::version too low (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A00018C:SSL routines::version too low, session=</3KXl6j4z8hnMTI1>
Apr 6 17:44:28 localhost dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:44:39 localhost postfix/smtpd[23658]: connect from unknown[103.49.50.53]
Apr 6 17:44:39 localhost postfix/smtpd[23658]: disconnect from unknown[103.49.50.53] ehlo=1 quit=1 commands=2
Apr 6 17:44:42 localhost dovecot: pop3-login: Disconnected: Connection closed (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:44:43 localhost dovecot: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol, session=
Apr 6 17:44:43 localhost dovecot: pop3-login: Disconnected: Connection closed: SSL_accept() failed: error:0A00018C:SSL routines::version too low (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A00018C:SSL routines::version too low, session=
Apr 6 17:44:46 localhost dovecot: pop3-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=<z+XXmKj44chnMTI1>
Apr 6 17:44:57 localhost dovecot: pop3-login: Disconnected: Aborted login by logging out (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:45:01 localhost dovecot: imap-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:45:25 localhost dovecot: imap-login: Disconnected: Connection closed (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=<6Ysqm6j47chnMTI1>
Apr 6 17:45:25 localhost dovecot: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A000102:SSL routines::unsupported protocol, session=
Apr 6 17:45:25 localhost dovecot: imap-login: Disconnected: Connection closed: SSL_accept() failed: error:0A00018C:SSL routines::version too low (no auth attempts in 0 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS handshaking: SSL_accept() failed: error:0A00018C:SSL routines::version too low, session=
Apr 6 17:45:28 localhost dovecot: imap-login: Disconnected: Aborted login by logging out (no auth attempts in 1 secs): user=<>, rip=103.49.50.53, lip=103.49.50.54, TLS, session=
Apr 6 17:45:35 localhost postfix/smtpd[23658]: connect from localhost[127.0.0.1]
Apr 6 17:45:35 localhost postfix/smtpd[23658]: 72FB6CE88F: client=localhost[127.0.0.1]
Apr 6 17:45:35 localhost postfix/smtpd[23658]: warning: connect to /var/log/policyServerSocket: No such file or directory
Apr 6 17:45:35 localhost postfix/trivial-rewrite[26116]: using backwards-compatible default setting append_dot_mydomain=yes to rewrite “bursanetws” to “bursanetws.swaralogika.co.id”
Apr 6 17:45:36 localhost postfix/smtpd[23658]: warning: connect to /var/log/policyServerSocket: No such file or directory
Apr 6 17:45:36 localhost postfix/smtpd[23658]: warning: problem talking to server /var/log/policyServerSocket: No such file or directory
Apr 6 17:45:36 localhost postfix/cleanup[26115]: 72FB6CE88F: hold: header Received: from [127.0.0.1] (localhost [127.0.0.1])??by mail.swaralogika.co.id (Postfix) with ESMTP id 72FB6CE88F??for technical@swaralogika.co.id; Thu, 6 Apr 2023 17:45:35 +0700 (WIB) from localhost[127.0.0.1]; from=root@bursanetws.swaralogika.co.id to=technical@swaralogika.co.id proto=ESMTP helo=<[127.0.0.1]>
Apr 6 17:45:36 localhost postfix/trivial-rewrite[26116]: using backwards-compatible default setting append_dot_mydomain=yes to rewrite “bursanetws” to “bursanetws.swaralogika.co.id”
Apr 6 17:45:36 localhost postfix/cleanup[26115]: 72FB6CE88F: message-id=20230406104535.72FB6CE88F@mail.swaralogika.co.id
Apr 6 17:45:36 localhost postfix/smtpd[23658]: disconnect from localhost[127.0.0.1] ehlo=1 mail=1 rcpt=1 data=1 commands=4
