I attempted installing Wordpress using wp-cli (as I commonly do).
But I can’t install due to it coming back with the error, “Error: Your PHP installation appears to be missing the MySQL extension which is required by WordPress.”
The website has PHP 7.3 assigned to it, and as far as I can tell the MySQL module is installed (as one would expect). I double checked that using, sudo dpkg --get-selections | grep -v deinstall | grep php which indicates
