Cannot use port 8443 for CyberPanel when firewall is enabled
I am using Cloudflare with CyberPanel. I am using one of the supported ports by Cloudflare: 8443. However, I cannot access the Cyberpanel when the firewall is enabled. Port 8443 is added to the exclusions, but for some reason, I cannot access the CyberPanel dashboard when the firewall is enabled. How do I add port 8443 to the exclusions?
Go security CSF and add there and check do you need add port on hosting firewall aswell.
Thanks! However, I enabled CSF without adding the port, how do I disable it?
NVM, I found it.
From terminal you can enabled and disable
