Yes, I restart the server, then crated another user account and now it shows me Access denied
Run the cyberpanel upgrade script
the same, nothing changed
but upgrading ended with this error
Enjoy your accelerated Internet by CyberPanel.
100 396 100 396 0 0 507 0 --:--:-- --:--:-- --:--:-- 507
Fetching latest data from CyberPanel server...
This may take few seconds...
Checking root privileges...
You are running as root...
Checking server location...
System: Ubuntu 20 detected...
Press the Enter key to continue with latest version, or enter specific version such as: 1.9.4 , 1.9.5 ...etc
If nothing is input in 10 seconds, script will proceed with the latest stable version.
Please press the Enter key or specify a version number, or wait for 10 seconds:
Branch name set to v2.3.4
Ign:1 http://rpms.litespeedtech.com/debian focal InRelease
Hit:2 http://archive.ubuntu.com/ubuntu focal InRelease
Hit:3 http://rpms.litespeedtech.com/debian focal Release
Get:4 http://archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Hit:6 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:7 http://archive.ubuntu.com/ubuntu focal-security InRelease
Fetched 114 kB in 3s (43.9 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
All packages are up to date.
Calculating upgrade... Done
Get more security updates through Ubuntu Pro with 'esm-apps' enabled:
libmagickcore-6.q16-6-extra libopenexr-dev libmagickwand-6.q16-6
libmagickwand-6-headers libmagickcore-6-headers libmagickcore-6-arch-config
libmagickwand-6.q16-dev libopenexr24 libmagickcore-6.q16-6 libmagickwand-dev
libmagickcore-6.q16-dev imagemagick-6-common
Learn more about Ubuntu Pro at https://ubuntu.com/pro
htop is already the newest version (2.2.0-2build1).
libattr1 is already the newest version (1:2.4.48-5).
libattr1-dev is already the newest version (1:2.4.48-5).
libidn2-0-dev is already the newest version (2.2.0-2).
libidn2-dev is already the newest version (2.2.0-2).
libpsl-dev is already the newest version (0.21.0-1ubuntu1).
librtmp-dev is already the newest version (2.4+20151223.gitfa8646d.1-2build1).
telnet is already the newest version (0.17-41.2build1).
idn2 is already the newest version (2.2.0-2).
git is already the newest version (1:2.25.1-1ubuntu3.11).
libcomerr2 is already the newest version (1.45.5-2ubuntu1.1).
libcurl4-gnutls-dev is already the newest version (7.68.0-1ubuntu2.21).
libgcrypt20-dev is already the newest version (1.8.5-5ubuntu1.1).
libgnutls28-dev is already the newest version (3.6.13-2ubuntu1.9).
libgpgme-dev is already the newest version (1.13.1-7ubuntu2.1).
libgssapi-krb5-2 is already the newest version (1.17-6ubuntu4.4).
libk5crypto3 is already the newest version (1.17-6ubuntu4.4).
libkrb5-dev is already the newest version (1.17-6ubuntu4.4).
libldap2-dev is already the newest version (2.4.49+dfsg-2ubuntu1.9).
liblzma-dev is already the newest version (5.2.4-1ubuntu1.1).
libnghttp2-dev is already the newest version (1.40.0-1ubuntu0.2).
libssl-dev is already the newest version (1.1.1f-1ubuntu2.20).
nettle-dev is already the newest version (3.5.1+really3.5.1-2ubuntu0.2).
dnsutils is already the newest version (1:9.16.1-0ubuntu2.16).
libmariadbclient-dev is already the newest version (1:10.3.38-0ubuntu0.20.04.1).
nghttp2 is already the newest version (1.40.0-1ubuntu0.2).
virtualenv is already the newest version (20.0.17-1ubuntu0.4).
python3-pip is already the newest version (20.0.2-5ubuntu1.10).
libffi-dev is already the newest version (3.3-4).
python3-dev is already the newest version (3.8.2-0ubuntu2).
build-essential is already the newest version (12.8ubuntu1.1).
python3-venv is already the newest version (3.8.2-0ubuntu2).
Hit:1 http://archive.ubuntu.com/ubuntu focal InRelease
Ign:2 http://rpms.litespeedtech.com/debian focal InRelease
Hit:3 http://archive.ubuntu.com/ubuntu focal-updates InRelease
Hit:4 http://rpms.litespeedtech.com/debian focal Release
Hit:5 http://archive.ubuntu.com/ubuntu focal-backports InRelease
Hit:6 http://archive.ubuntu.com/ubuntu focal-security InRelease
Requirement already satisfied: virtualenv==16.7.9 in /usr/local/lib/python3.8/dist-packages (16.7.9)
No need to re-setup virtualenv at /usr/local/CyberPanel...
--2023-12-20 22:45:15-- https://raw.githubusercontent.com/usmannasir/cyberpanel/v2.3.4/requirments.txt
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 69.197.146.180
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|69.197.146.180|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1461 (1.4K) [text/plain]
Saving to: β/usr/local/requirments.txtβ
/usr/local/requirments.txt 100%[==================================================================================>] 1.43K --.-KB/s in 0s
2023-12-20 22:45:16 (9.87 MB/s) - β/usr/local/requirments.txtβ saved [1461/1461]
File "/usr/local/CyberPanel/bin/pip3", line 8, in <module>
sys.exit(main())
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/cli/main.py", line 68, in main
command = create_command(cmd_name, isolated=("--isolated" in cmd_args))
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/commands/__init__.py", line 114, in create_command
module = importlib.import_module(module_path)
File "/usr/local/CyberPanel/lib/python3.8/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 848, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/commands/install.py", line 16, in <module>
from pip._internal.cli.req_command import (
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/cli/req_command.py", line 20, in <module>
from pip._internal.index.collector import LinkCollector
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/index/collector.py", line 37, in <module>
from pip._internal.network.session import PipSession
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/network/session.py", line 44, in <module>
from pip._internal.network.cache import SafeFileCache
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_internal/network/cache.py", line 9, in <module>
from pip._vendor.cachecontrol.caches import FileCache
File "/usr/local/CyberPanel/lib/python3.8/site-packages/pip/_vendor/cachecontrol/caches/__init__.py", line 6, in <module>
from .redis_cache import RedisCache
ModuleNotFoundError: No module named 'pip._vendor.cachecontrol.caches.redis_cache'
above command failed...
On the cyberpanel dashboard go to Manage Applications section, find the Redis option and click on Install
What error do you see on SSH terminal
ModuleNotFoundError: No module named βpip._vendor.cachecontrol.caches.redis_cacheβ
above command failedβ¦
I was avoiding the installation of python modules since cyberpanel should handle this through its update scripts etc. Run this
pip3 install redis
Thanks for helping me
Install the redis with that command, restart the ubuntu and run update of cyberpanel agin but this is happen
Did you run pip3 install redis
Yes
root@secondserverhpe:~# pip install redis
Collecting redis
Downloading redis-5.0.1-py3-none-any.whl (250 kB)
|ββββββββββββββββββββββββββββββββ| 250 kB 160 kB/s
Collecting async-timeout>=4.0.2; python_full_version <= "3.11.2"
Downloading async_timeout-4.0.3-py3-none-any.whl (5.7 kB)
Installing collected packages: async-timeout, redis
Successfully installed async-timeout-4.0.3 redis-5.0.1
Then I used this
sudo apt update && sudo apt upgrade -y
then
sudo sh sh <(curl https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh || wget -O - https://raw.githubusercontent.com/usmannasir/cyberpanel/stable/preUpgrade.sh)
That is not pip3
root@secondserverhpe:~# pip3 install redis
Requirement already satisfied: redis in /usr/local/lib/python3.8/dist-packages (5.0.1)
Requirement already satisfied: async-timeout>=4.0.2; python_full_version <= "3.11.2" in /usr/local/lib/python3.8/dist-packages (from redis) (4.0.3)
Is that right now?
