Cannot create a remote backup "error message: TempStorage"
[11.05.2024_00-22-54] Currently generating local backups for: asdasd.com.br
[11.05.2024_00-22-54] Starting local backup for: asdasd.com.br
[11.05.2024_00-22-54] Local backup creating failed for asdasd.com.br, Error message: 'tempStorage'
[11.05.2024_00-22-54]Failed to generate local backup for: asdasd.com.br. Error message: 'tempStorage'
[11.05.2024_00-22-54] Backups are successfully generated and received on: serverip
That’s what I get for any backups, I’m trying to transfer to a new server from a malware-ridden server that got infected by the security problem last week
I think I deleted a .tempstorage or .tmpstorage file somewhere in the old server that I don’t remember where was, that could be one of the causes ^^’
How do I fix it so I can get myself rid of the old server ASAP?
There is also a problem with my backup
Did you solve the problem?
I have the same issue…
Later edit: @RMisaki I have upgraded to v2.3.9 commit 6f28d39a591b5e08aac6adfcc59b642a58622ea2 and ran the command
/usr/local/CyberCP/bin/python /usr/local/CyberCP/plogical/IncScheduler.py Daily
and … it worked. Performed the backup and sent it to google drive.
