i created ftp account with default home directory, but still cannot connect to ftp. Filezilla error : Error: Could not read from socket: ECONNRESET - Connection reset by peer
Error: Could not connect to server
how to solve this?
Are you able to connect after you disable the firewall?
Server > Security > Firewall > Stop
Still cannot connect, error appear after SSL auth, i have issued SSL to the domain.
This the FTP logs
Feb 23 07:22:51 localhost firewalld[26320]: WARNING: beyond-scope: INVALID_ICMPTYPE: No supported ICMP type., ignoring for run-time.
Feb 23 07:22:51 localhost firewalld[26320]: WARNING: ICMP type ‘failed-policy’ is not supported by the kernel for ipv6.
Feb 23 07:22:51 localhost firewalld[26320]: WARNING: failed-policy: INVALID_ICMPTYPE: No supported ICMP type., ignoring for run-time.
Feb 23 07:22:51 localhost firewalld[26320]: WARNING: ICMP type ‘reject-route’ is not supported by the kernel for ipv6.
Feb 23 07:22:51 localhost firewalld[26320]: WARNING: reject-route: INVALID_ICMPTYPE: No supported ICMP type., ignoring for run-time.
Feb 23 07:26:18 localhost gunicorn: cat: /tmp/lshttpd/.rtreport: No such file or directory
Feb 23 07:26:32 localhost gunicorn: cat: /tmp/lshttpd/.rtreport: No such file or directory
Feb 23 07:27:29 localhost pure-ftpd: (?@158.140.166.21) [INFO] New connection from 158.140.166.21
Feb 23 07:27:29 localhost pure-ftpd: (?@158.140.166.21) [WARNING] Sorry, cleartext sessions and weak ciphers are not accepted on this server.#012Please reconnect using SSL/TLS security mechanisms.
Feb 23 07:27:34 localhost pure-ftpd: (?@158.140.166.21) [INFO] New connection from 158.140.166.21
Feb 23 07:27:35 localhost pure-ftpd: (?@158.140.166.21) [WARNING] Sorry, cleartext sessions and weak ciphers are not accepted on this server.#012Please reconnect using SSL/TLS security mechanisms.
Feb 23 07:28:16 localhost systemd-logind: Removed session 168.
Feb 23 07:28:16 localhost systemd: Removed slice User Slice of root.
Feb 23 07:28:16 localhost systemd: Stopping User Slice of root.
Feb 23 07:30:01 localhost do-agent[1261]: 2018/02/23 07:30:01 Checking for newer version of do-agent
Feb 23 07:30:01 localhost do-agent[1261]: 2018/02/23 07:30:01 No repository update available
Feb 23 07:39:08 localhost rsyslogd: imjournal: journal reloaded… [v8.24.0 try http://www.rsyslog.com/e/0 ]
Feb 23 07:42:27 localhost pdns_server: Not validating response for security status update, this is a non-release version.
Feb 23 08:00:01 localhost systemd: Created slice User Slice of root.
Feb 23 08:00:01 localhost systemd: Starting User Slice of root.
Feb 23 08:00:01 localhost systemd: Started Session 169 of user root.
Feb 23 08:00:01 localhost rsyslogd: imjournal: journal reloaded… [v8.24.0 try http://www.rsyslog.com/e/0 ]
Feb 23 08:00:01 localhost systemd: Starting Session 169 of user root.
Submit a support request: https://cyberpanel.net/support/
Ticket submitted
This is NOT the problem of firewall.
I just finished an installation about an hour ago, and got the same problem.
My ftp client is flashfxp, and I didn’t use normal FTP mode, but switch to AuthSSL option from the dropdown menu. When I tried to connect to the site via ftp, I didn’t install my SSL certificate.
Send your FTP logins via ticket.
i have same issue, pleasee… i have stopp firewall
I am too facing issue and searching for solution. Any one any solution?
FTP does not work!
this should be very simple, please find a cure for it. my work is incomplete.
this is a pureftpd issue it cannot start itself.
