Hi, I’m new to cyberpanel and I’ll only be running a wordpress site on my vps at the moment, the configuration is AMD EPYC™ 7702
8 GB DDR4 RAM (ECC)
4 dedizierte Kerne
160 GB SSD, and about 75 plugins on the backend.
I got the values wrong, and I forgot the previous values, causing my site to not work properly, can you help me? If you can, it would be better to give me an optimal value, that would be even better.
LITESPEED TUNING:
Max Connections
Max SSL Connections
Connection Timeout
Keep Alive Timeout
Cache Size in memory
Enable GZIP Compression
PHP TUNING:
Initial Request Timeout (secs)
Max Connections
Memory Soft Limit
Memory Hard Limit
Process Soft Limit
Process Hard Limit
Persistent Connection
EDIT PHP CONFIGURATIONS
memory_limit
max_execution_time
upload_max_filesize
post_max_size
max_input_time
Please help me, I’ve searched a lot and I really don’t know how to set it up.
