When I tried to install Cyberpanel I saw it trying to install epel-release-latest-7.noarch.rpm at: https://dl.fedoraproject.org/pub/epel/epel-release-latest-7.noarch.rpm
However, that link is dead and the installation continues. Then I get the error:
Building wheels for collected packages: mysqlclient, psutil
Building wheel for mysqlclient (setup.py) ... error
command: /usr/local/CyberPanel/bin/python -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-7p7gvhb2/mysqlclient_2743c57ee45c47aba9e06865aff3078a/setup.py'"'"'; __file__='"'"'/tmp/pip-install-7p7gvhb2/mysqlclient_2743c57ee45c47aba9e06865aff3078a/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-5rq8umv6
cwd: /tmp/pip-install-7p7gvhb2/mysqlclient_2743c57ee45c47aba9e06865aff3078a/
Complete output (30 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.6
creating build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/__init__.py -> build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/_exceptions.py -> build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/connections.py -> build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/converters.py -> build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/cursors.py -> build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/release.py -> build/lib.linux-x86_64-3.6/MySQLdb
copying MySQLdb/times.py -> build/lib.linux-x86_64-3.6/MySQLdb
creating build/lib.linux-x86_64-3.6/MySQLdb/constants
copying MySQLdb/constants/__init__.py -> build/lib.linux-x86_64-3.6/MySQLdb/constants
copying MySQLdb/constants/CLIENT.py -> build/lib.linux-x86_64-3.6/MySQLdb/constants
copying MySQLdb/constants/CR.py -> build/lib.linux-x86_64-3.6/MySQLdb/constants
copying MySQLdb/constants/ER.py -> build/lib.linux-x86_64-3.6/MySQLdb/constants
copying MySQLdb/constants/FIELD_TYPE.py -> build/lib.linux-x86_64-3.6/MySQLdb/constants
copying MySQLdb/constants/FLAG.py -> build/lib.linux-x86_64-3.6/MySQLdb/constants
running build_ext
building 'MySQLdb._mysql' extension
creating build/temp.linux-x86_64-3.6
creating build/temp.linux-x86_64-3.6/MySQLdb
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -Dversion_info=(2,0,1,'final',0) -D__version__=2.0.1 -I/usr/include/mysql -I/usr/include/mysql/mysql -I/usr/local/CyberPanel/include -I/usr/include/python3.6m -c MySQLdb/_mysql.c -o build/temp.linux-x86_64-3.6/MySQLdb/_mysql.o
MySQLdb/_mysql.c:46:20: fatal error: Python.h: No such file or directory
#include "Python.h"
compilation terminated.
error: command 'gcc' failed with exit status 1
ERROR: Failed building wheel for mysqlclient
Running setup.py clean for mysqlclient
Building wheel for psutil (setup.py) ... error
command: /usr/local/CyberPanel/bin/python -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-7p7gvhb2/psutil_b5e63628977c4b10823d9f50a5c89095/setup.py'"'"'; __file__='"'"'/tmp/pip-install-7p7gvhb2/psutil_b5e63628977c4b10823d9f50a5c89095/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-gh9pe1ka
cwd: /tmp/pip-install-7p7gvhb2/psutil_b5e63628977c4b10823d9f50a5c89095/
Complete output (45 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.6/psutil
copying psutil/_pswindows.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_psbsd.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_compat.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_common.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_psposix.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/__init__.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_psaix.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_pslinux.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_pssunos.py -> build/lib.linux-x86_64-3.6/psutil
copying psutil/_psosx.py -> build/lib.linux-x86_64-3.6/psutil
creating build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_aix.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_system.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_testutils.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_bsd.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_connections.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_memleaks.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_unicode.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_posix.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_windows.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_misc.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_sunos.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/__init__.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_osx.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_process.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_linux.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/__main__.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/test_contracts.py -> build/lib.linux-x86_64-3.6/psutil/tests
copying psutil/tests/runner.py -> build/lib.linux-x86_64-3.6/psutil/tests
running build_ext
building 'psutil._psutil_linux' extension
creating build/temp.linux-x86_64-3.6/psutil
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_SIZEOF_PID_T=4 -DPSUTIL_VERSION=573 -DPSUTIL_LINUX=1 -I/usr/local/CyberPanel/include -I/usr/include/python3.6m -c psutil/_psutil_common.c -o build/temp.linux-x86_64-3.6/psutil/_psutil_common.o
psutil/_psutil_common.c:9:20: fatal error: Python.h: No such file or directory
#include <Python.h>
ERROR: Failed building wheel for psutil
Running setup.py clean for psutil
Failed to build mysqlclient psutil
Installing collected packages: psutil, pexpect, mysqlclient, ipaddress, google-auth-oauthlib, google-api-python-client, docker, Django, cloudflare, boto3
Running setup.py install for psutil ... error
command: /usr/local/CyberPanel/bin/python -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-7p7gvhb2/psutil_b5e63628977c4b10823d9f50a5c89095/setup.py'"'"'; __file__='"'"'/tmp/pip-install-7p7gvhb2/psutil_b5e63628977c4b10823d9f50a5c89095/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-rzyf4h8u/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/CyberPanel/include/site/python3.6/psutil
Complete output (47 lines):
running install
/usr/local/CyberPanel/lib/python3.6/site-packages/setuptools/command/install.py:37: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
setuptools.SetuptoolsDeprecationWarning,
running build
running build_py
creating build
running build_ext
#include <Python.h>
ERROR: Command errored out with exit status 1: /usr/local/CyberPanel/bin/python -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-7p7gvhb2/psutil_b5e63628977c4b10823d9f50a5c89095/setup.py'"'"'; __file__='"'"'/tmp/pip-install-7p7gvhb2/psutil_b5e63628977c4b10823d9f50a5c89095/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-rzyf4h8u/install-record.txt --single-version-externally-managed --compile --install-headers /usr/local/CyberPanel/include/site/python3.6/psutil Check the logs for full command output.
I tried canceling the installation, then trying to install epel-release via yum install epel-release (version 7-14).
After the installation completed, I tried to run the cyberpanel install script again. But it uninstalled epel-release above and tried to install via the dead link above and the installation error loop started again.
Please fix this error.
