Trying to access docker container from IP:8090/docker/listContainers and when the launch button is clicked instead of opening IP:8090/docker/view/container_name it redirects to IP:8090/base
@josephgodwinke apologies to mention you.
Can you help please.
Seems to be this issue - [BUG] Container view redirecting to dashboard · Issue #1007 · usmannasir/cyberpanel · GitHub can you add your findings there before creating new issue there
Yes, it is the same issue.
has this bug been fixed? it seems that it is still there, unfortunately I have the same problem with ubuntu22.04, do you recommend me to try with an almalinux ?
