Version Management tab in CyberPanel is now showing a v3.0.0 as a selctable branch - but I can’t find any information on this anywhere? Can somebody point me to changelogs etc. please before I upgrade…
Thank you.
Thank you.
As of today v2.3.5 is stable, v3.0.0 is not stable branch it will be released with new design.
Thank you @usmannasir
This should certainly be renamed to reflect this on the Version Management tab. Currently it looks as if this is the latest, current version…
sure yes. was a mistake on our end.
I agree with Mick; I almost updated it by mistake because I thought the same. However, after checking the changelog, I realized that it wasn’t the stable version.
This will likely lead many less advanced users to unintentionally update to a ‘beta version’ or a ‘development version’.
@usmannasir - It has been over three months and this is still a problem. A little worrying for early adopters who can see easily removed bugs not being actioned…
@usmannasir is version 3.0.0 now stable?
Thank you.
It has been a year and a half and it is still a problem.
2.4.2, which appears to be “stable” production, appears to use the new UI in new fresh and clean install. Don’t. It has UI bugs that break entry in numerous areas. Avoid. I recommend using pre 2.4 builds.
