I’ve been trying to figure out the best method for using this WordPress plugin in full WAF mode on my website and just can’t seem to figure it out.
Does anyone know the steps I need to get this done properly?
Mod_security does this job better no?
I’m not sure. I’m new to this platform.
I’ve just been used to using NinjaFirewall so I started moving stuff over and ran into this issue.
I do remember Mod_security being installed so if that’s done during the initial install of CyberPanel then I don’t have to enable or adjust anything else?
You should enable mod_security Comodo or OWASP rule pack. The default setting rule is not enough.
Hrmm, no matter which of these I enable, I am getting errors when trying to upload images to the gallery or execute scripts from a plugin.
I have to disable the rule pack just to perform one of these tasks.
Any idea on how I can fix this?
