I am new to CyberPanel and learning constantly and I am looking for some help and guidance. I am facing a bit of a misunderstanding of the backup terminology on Cyberpanel.
What is the difference between a Backups and Incremental Backups? Which one should I use to backup my websites if something wents wrong? I want to backup to a remote server/space and I want to do daily backups.
However I see that Incremental Backups have the option to restore from remote server but Backups do not.
Thanks again for your response. I am sorry since I am really new to this control panel. I did setup a SFTP destination, how every when i try to restore, it only shows me the backups on /home/backup folder. As i dont have any backups on this folder its shows an empty option. How do I restore these remote backups on my SFTP?
You can download files from your remote server and put them in /home/backup.
With incremental backups if you loose a complete access to your server you will loose your backups. With normal backups even if you loose server access you have backups stored remotely.
Not working to restore, getting this error
Error Message: ‘NoneType’ object has no attribute ‘text’. Not able to create Account, Databases and DNS Records, aborting. [575][5009]
