I select in the panel to take a new backup but it doesn’t make one. Do I need to add some cron job?
Same with me backup not working v7.1…
OpenVZ, KVM or else?
There was a minor bug, hot-fix released, you can force upgrade http://docs.cyberpanel.net/doku.php?id=upgrade
Thanks i can now create a backup but cant restore blank on dropdown box…
This page can be used to restore your websites, Back up should be generated from CyberPanel Back up generation tool, it will detect all Back ups under /home/backup
And backups are generated at /home/domain.com/backup, so you need to move them manually.
Ah ok thank u… Last how long the panel keeps the backups
As long as you wont delete them.
