Dear Team ,
I have been created backup and select destination home I want to restore it but the restore option showing empty ,
Thanks in advance for your support and help
Copy the backup file from /home/website/backup to the /home/backup and then you can restore
I cant copy to home but not allowed ,
the backup inside home/website/backup
i tried fix permission but still the same issue
Copy using ssh terminal
Thank you elhamdlilah the problem has been solved after moving the backup folder to /home viw ssh terminal
i used cp -r /home/yalmutairi.com/backup/ /home/
