I am using
for backup process. Before installing cyberpanel, it works fine, but when I install cyberpanel, I got permission issue.
Failed to execv() /tmp/staticx-HgnoAK/b2: Permission denied
Can you please help in it?
Thanks
I am using
Thanks
Welcome @perochak Hapy you are here
On your CyberPanel dashboard go to Websites → mycoolwebsite.com → File Manager → Fix Permissions
I think, its not related to a single website.
When I run command
backblaze authorize-account
it gives
Failed to execv() /tmp/staticx-FGMNDG/b2: Permission denied
error
Post screenshot please
RUn sudo chmod -t /tmp
and try to authorize account again
/tmp
folder has the sticky bit flag to prevent ordinary users from deleting or moving other users’ files.
still same
Run
sudo chmod -t /tmp
sudo chmod 777 /tmp
still same
sudo chmod -t /tmp
# this changed
sudo chmod -R 777 /tmp
same
# rerun from here
sudo chmod -t /tmp
# this changed
sudo chmod 0777 /tmp
ls -l | grep tmp
# post screenshot first do not run backblaze
I see its failing because it creates a folder inside /tmp therefore it means access to /tmp. Actually removing the sticky bit from /tmp is not advisable. Can you fork the repo and i can guide you where to change to make this work
No. This not what we are trying to diagnose. I believe this is what we are trying to make it work
I am using that library.
if you mean some other lib, than kindly let me know.
Then change your post. It is misleading
I just forked it so I can make changes as you suggest. Its same repo just forked to my account
Kindly recheck what you posted. One repo is a community contribution for backblaze backups (in your topic) now you are talking about an official python command-line tool for backblaze backups.
I can only help you with GitHub - Coma-Web-Development/backblaze-backup as discussed in all the screenshots you posted
