If anyone has files encrypted with .encryp, try it out
Warning: When decrypting, save important encrypted files and delete them only after thorough verification! Babuk ransomware is known to be dangerous, as it can damage files during the decryption process due to a lack of metadata checks.
Decryption Instructions
Follow these steps carefully to decrypt files affected by the Babuk ransomware. Be sure to back up your encrypted files before proceeding, as the decryption process may corrupt files if not handled properly.
Steps
- Upload Decryptor
Upload theencryp_dec.out
file to the/tmp
directory on your system. - Set Executable Permissions
Grant executable permissions to the decryption file by running the following command:
chmod +x ./encryp_dec.out
- Run Decryptor
Execute the decryptor with the directory containing your encrypted files. Replace/your_dir
with the actual path to the directory where your encrypted files are located.
./encryp_dec.out /your_dir
Important Notes
- Backup First: Make sure to backup your encrypted files before running the decryptor. Verify the integrity of the decrypted files before deleting any backups.
- Metadata Caution: Babuk ransomware may cause file damage as it does not verify metadata during decryption. Proceed with caution to avoid data loss.
For any questions or further assistance, consult a cybersecurity professional.
