Yes Sir This is a Valid Domain…
I am Creating Anader Website Emain But Slill This Problem…
This an issue with python3 which is used to create cyberpanel where there is a unicode decode error caused when it uses the ascii encoding to decode a bytes object that was encoded in a different encoding say utf-8.
ordinal not in range(128)
This part it seems that the cyberpanel code is trying to decode an already existing unicode object
- Which server os is this ?
- Which version of cyberpanel is this ?
- Sir I am Using Contabo VPS Server
- cyber panel 2.3
Ubuntu 20.04 or ?
Ubuntu 20.04 (64 Bit)
Run cyberpanel upgrade script
Sir, I was running an update script after the problem but the boot didn’t fix
I have the same problem with a “normal” domain name and email
Cyber panel have a lot of issues and not easy to solve them ![]()
and i updated Cyberpanel so i use the last version
someone can help?
