CyberPanel works on ARM without any issue. There were minor bugs related to rustic and lsws ent which have also been resolved recently.
Now lscpd is taking long to restart could be for one reason but I am not sure it was not built for ARM. But that is something not going to stop you from using CyberPanel on ARM.
I will check with LSCPD dev (which powers CyberPanel and port 8090) to see why it loads slow on reboot.
Did you finally get to talk about this with the LSCPD dev? It is to know if I can try to use my Oracle server with ARM to see how it works in performance.
On the other hand, version 3.0.0 appears without beta or dev, I understand that it is already a stable version?
Ah, ok. I only have one ARM instance and it has production websites so I am cautious to do an experiment. I might get a Hetzner ARM for a month and experiment. Has lscpd been updated in 3.0.0 as a fix or are you just asking if it is fixed?
See if it works for you.
When prompted during the upgrade just enter 3.0.0, if it fails you can rerun the script and don’t enter anything and it will go back to 2.3.5
I haven’t tried yet as my only arm instance is production so am cautious about upgrade to a beta.
I tried an upgrade on an x64 instance as above to 3.0.0 but it didn’t work. It wouldn’t upgrade from 2.3.5. can you suggest how to upgrade to 3.0.0?
