fr
ClosedApt Upgrade doesn't work anymore
ay
ayobpro
#2
based on your ss failed to write (No space left on device)
Check your server disk space.
fr
Thank you @ayobpro
Well, it says this
ay
ayobpro
#4
Sorry for late reply, i think your /boot is full. Try run this command on terminal and sent it here.
sudo df -h
fr
Thank You @ayobpro
Please see below.
ay
ayobpro
#6
As you can see your /dev/md1 (/boot) is used 100%. You can try clean up your /dev/md1 but please do it carefully.
fr
Thank you so much for your help!
BTW, any specific measures I should take before deleting the files in that dir?
ay
ayobpro
#8
Sorry for late reply. Read and understand first before apply it. hard drive - How do I free up more space in /boot? - Ask Ubuntu
