Bayrem
April 24, 2021, 11:39pm
1
Hi there i upgraded my Cyberpanel to the last one
first of all when it’s installing files and things the installing stuck on
it stuck on [04.24.2021_23-32-00] #########################################################################
[04.24.2021_23-32-00] LSCPD successfully installed!
for hours and hours
and if you want to access the panel it’s just loading for hours and hours
Me either! it stuck at LSCPD successfully installed! message
Bayrem
April 26, 2021, 9:41am
4
Such a nice Panel but a very Bad support, bad Documentation !!!
henscu
April 26, 2021, 4:25pm
5
I just had this problem, and found the solution on the Facebook Cyberpanel Group at this link:
https://www.facebook.com/groups/cyberpanel/permalink/2775712146073749/
The solution is: Just press the ‘Enter’ or ‘Return’ key. Then the upgrade will continue…
Yes, it looks like the upgrade is just waiting for user input after LSCPD successfully installed…
Bayrem
April 26, 2021, 6:28pm
6
You are not just Amazing but a Wonderful, astonishing, excellent guy
Thank you
:))) LOL
