Add_rewrite_rule function (wordpress) doesn't work
I can’t overwrite the rules in WP through add_rewrite_rule function , I suspect this is related to the server settings.
I can’t rewrite the rules, I suspect that this is due to the server setting, because when I even manually tried to rewrite the link with the get parameter, it didn’t affect anything.
For the test, I decided to try creating a rule directly in the htacess file
RewriteRule ^user([0-9]+)$ /index.php?id=$1 [L]
GET site.com/?id=1
Expect to receive site.com/user1
But nothing happens
You have to restart openlitespeed after modifying .htaccess.
Try that if you did not already do it.
