Hello
After upgrade to 1.9.0 version begins to happens this :
When we open hostname.domain.com:8090 appears the login form correctly, but when i login, i get error 404 not found at
hostname.domain.com:8090/base
Then, i delete /base from the URL on the browser, and the panel load perfect.
Any help?
Thanks
Fabian
Did you try private window or tried clearing browser cache?
You right… very weird!
In Chrome:
https://hostname.domain.com:8090 open the login form
after login, go to https://hostname.domain.com:8090/base/ and get 4040 error
In Edge or Firefox:
go to the eactly same page : https://hostname.domain.com:8090/base/ and works perfect
Thanks
Fabian
this occur on my server too,
…/base/ is work
but /base does not work
where to edit them to become /base/ or on home after login
thanks
Clear your browser cache @planetjoin @roziqbahtiar
