Hello Team, I upgrade to Ubuntu 20.04 from 18.04 around 24 hours back. It was all working fine. But all of sudden I started getting error 503 Service Unavailable on port 8090 if I am trying to access CyberPanel (hosted websites are working fine).
Can you restart your server and see if that resolve the issue.
Try the troubleshooting section here too 01 - Installing CyberPanel
Can you please check the status of cyberpanel demon?
Run systemctl status lscpd
Check CyberPanel status first: please share a screenshot of the situation:
check CyberPanel status on this command:
● lscpd.service - LSCPD Daemon
Loaded: loaded (/etc/systemd/system/lscpd.service; enabled; vendor preset: enabled)
Active: *active* (**running**) since Mon 2021-12-06 19:41:39 IST; 22h ago
Main PID: 1152 (lscpd)
CGroup: /system.slice/lscpd.service
├─1152 lscpd (lscpd - main)
├─1155 lscpd (lscgid)
├─1156 lscpd (lscpd - #01)
└─9259 lsphp
Dec 06 19:41:36 infolink systemd[1]: Starting LSCPD Daemon...
Dec 06 19:41:37 infolink lscpdctrl[1079]: [OK] lscpd: pid=1152.
Dec 06 19:41:39 infolink systemd[1]: Started LSCPD Daemon.
Hi, Thanks for your reply. I tried troubleshooting too but no luck.
Which Hosting is this? Seems 100% CPU usage.
You can provide me SSH login via PM to check the error and help you out if you wish.
I am using a small own built server, but CPU usage was always 3-4% only. I can help you with SSH Access on AnyDesk If you wish as per your convenience of time. Thanks!
Run systemctl restart lscpd and check.
Done already, no luck
Can anyone please fix this?
Do PM me with your SSH login or anydesk or anything such. I will take a look
