503 Error When Accessing Admin Panel
I removed the 8090 port and added a domain called “management.domain.com” to access my CyberPanel administrative area. I followed this tutorial here: How to remove port 8090 from CyberPanel
However, when I try accessing it, I get a 503 Error page. The logs don’t show much, except this:
2022-05-18 18:53:14.027184 [NOTICE] [5113] [Internal IP:25538:HTTP2-1#management.domain.com] ExtConn timed out while connecting.
2022-05-18 18:53:16.030645 [NOTICE] [5113] [Internal IP:25538:HTTP2-1#management.domain.com] ExtConn timed out while connecting.
2022-05-18 18:53:18.035109 [NOTICE] [5113] [Internal IP:25538:HTTP2-1#management.domain.com] ExtConn timed out while connecting.
2022-05-18 18:53:18.035255 [NOTICE] [5113] [Internal IP:25538:HTTP2-1#management.domain.com] oops! 503 Service Unavailable
2022-05-18 18:53:18.035264 [INFO] [5113] [Internal IP:25538:HTTP2-1] Content len: 0, request line: ‘GET / HTTP/1.1’
2022-05-18 18:53:18.035269 [INFO] [5113] [Internal IP:25538:HTTP2-1] Redirect: #1, URL: /
I can access all my other websites just fine, including the panel through its public IP.
Does anybody know how to debug/fix it?
Thanks!
If you using cloudflare disable proxy (gray cloud on DNS settings) and make sure you open port on firewall.
Disabling Cloudflare proxy and restarting OLS seems to have resolved it. However, I remember a few days ago being able to remove the 8090 port and still have Cloudflare proxy on.
Do you know how I can keep Cloudflare proxy on and still have the port removed? I wouldn’t like to leave my IP exposed.
If you want use cloudflare on panel google ports accepted by cloudflare and use one of those.
I had been using 8993, but I was also having issues with it, something like 526 Invalid Certificate, even though I had added an origin server certificate from Cloudflare on all domains. :sweat:
Try port 8443 that’s https allowed port on cloudflare
Sorry, I meant to say 8443. That’s the port I’d been using.
