Hi there.
After visiting https://:8090/base/design and saving my edits multiple times, suddently I’m greeted with 500 error page with following error trace:
Environment:
Request Method: GET
Request URL: https://<domain>:8090/base/design
Django Version: 3.1.3
Python Version: 3.10.12
File "/usr/local/CyberCP/lib/python3.10/site-packages/django/core/handlers/exception.py", line 47, in inner
response = get_response(request)
File "/usr/local/CyberCP/lib/python3.10/site-packages/django/core/handlers/base.py", line 179, in _get_response
response = wrapped_callback(request, *callback_args, **callback_kwargs)
File "/usr/local/CyberCP/lib/python3.10/site-packages/django/utils/decorators.py", line 130, in _wrapped_view
response = view_func(request, *args, **kwargs)
File "/usr/local/CyberCP/baseTemplate/views.py", line 312, in design
sha = sha_res.json()[0]['sha']
Exception Type: KeyError at /base/design
Exception Value: 0
I tried to:
- Double checked, that CSS code has no errors (works on other server’s CyberPanel);
- Restart
lscpd.service- error persists; - Restart server - error persists;
- Remove CSS style from database table
baseTemplate_cyberpanelcosmetic- error persists; - Upgraded CyberPanel - error persists;
Error is comming from file /usr/local/CyberCP/baseTemplate/views.py on line 312
How can I revert this or workaround it?
U P D A T E
Both - removing CSS style from database table baseTemplate_cyberpanelcosmetic AND upgrading CyberPanel seems to have solved the issue, but when I start editing template’s CSS, after ~10 time saving it again crashes with the same error and no restart or resetting baseTemplate will fix it.
Regards,
Richard
