I have completed the installation but I am typing my ip address in the browser gives 404 not found error
Go to “fix permissions” on File Manager. Apply to public_html. If doesn’t work you can go to Suspend/Un-Suspend. First suspend, and then un-suspend website.
This method always works.
where can i find what you said
Suspend/Un-Suspend: http://prnt.sc/sezcj8
The Fix Permissions button is on the File Manager.
- List Websites
- Manage
- File Manager
- Fix Permissions button
Let me know if you make it!
Are you on Google Cloud? Let us know. Definitely is a problem with the firewall of your instance.
no i installed it on vps
Which VPS provider are you using?
