Hello dear friends,
I have issue with multistore mode on prestashop. it works with apache but 404 with openlitespeed.
main domain is civilkala.com and multistore page is “civilkala.com/seller”. “civilkala.com/seller” works fine but other URLS under “civilkala.com/seller” dosen’t work.
(for example this page: ‘www.civilkala.com/seller/brand/12_’)
this is my .htaccess codes:
start Do not remove this comment, Prestashop will keep automatically the code outside this comment when .htaccess will be generated again
.htaccess automaticaly generated by PrestaShop e-commerce open-source solution
http://www.prestashop.com - http://www.prestashop.com/forums
SetEnv HTTP_MOD_REWRITE OnRewriteEngine on
#Domain: www.civilkala.com
RewriteCond %{HTTP_HOST} ^www.civilkala.com$
RewriteRule . - [E=REWRITEBASE:/]
RewriteRule ^api$ api/ [L]
RewriteRule ^api/(.*)$ %{ENV:REWRITEBASE}webservice/dispatcher.php?url=$1 [QSA,L]
Images
RewriteRule ^([0-9])(\-[_a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$1$2$3.jpg [L]
RewriteRule ^([0-9])([0-9])(\-[_a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$1$2$3$4.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])(\-[_a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$1$2$3$4$5.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])(\-[_a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$1$2$3$4$5$6.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])(\-[_a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$1$2$3$4$5$6$7.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(\-[_a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$1$2$3$4$5$6$7$8.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(\-[a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$7/$1$2$3$4$5$6$7$8$9.jpg [L]
RewriteRule ^([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])([0-9])(\-[_a-zA-Z0-9-])?(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/p/$1/$2/$3/$4/$5/$6/$7/$8/$1$2$3$4$5$6$7$8$9$10.jpg [L]
RewriteRule ^c/([0-9]+)(\-[\._a-zA-Z0-9-])(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/c/$1$2$3.jpg [L]
RewriteRule ^c/([a-zA-Z-]+)(-[0-9]+)?/.+\.jpg$ %{ENV:REWRITEBASE}img/c/$1$2.jpg [L]
AlphaImageLoader for IE and fancybox
RewriteRule ^images_ie/?([^/]+)\.(jpe?g|png|gif)$ js/jquery/plugins/fancybox/images/$1.$2 [L]
RewriteRule ^seller$ /seller/ [L,R]
RewriteRule ^seller/(.*) /$1 [L]
Images
Dispatcher
RewriteCond %{REQUEST_FILENAME} -s [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.$ - [NC,L]
RewriteRule ^.$ %{ENV:REWRITEBASE}index.php [NC,L]
AddType application/vnd.ms-fontobject .eot
AddType font/ttf .ttf
AddType font/otf .otf
AddType application/font-woff .woff
AddType font/woff2 .woff2
<FilesMatch “\.(ttf|ttc|otf|eot|woff|woff2|svg)$”>
Header set Access-Control-Allow-Origin “*”
#If rewrite mod isn’t enabled
ErrorDocument 404 /index.php?controller=404
end Do not remove this comment, Prestashop will keep automatically the code outside this comment when .htaccess will be generated again
Thanks in advance for your help.
Best Regards.
