Closed OpenLitespeed web console not working
jo
josephgodwinke #2
Hello @av_admin
What do you mean? I did not propose you do anything that would change how cyberpanel works. Also what did you do that caused this error
kindly be clear with your topic you are mixing wordpress errors and issues that concern accessing OLS webadmin console
an
antivirusadmin #3
Hello @josephgodwinke
Thanks for very fast respond :rose:
about 20 min ago I found that my sites in this server give me this error:
I did thes steps:
sudo apt-get clean
sudo mv /var/lib/apt/lists /tmp
sudo mkdir -p /var/lib/apt/lists/partial
sudo apt-get clean
sudo apt-get update
and reboot the droplet.
and then reboot , but nothing happen …
jo
josephgodwinke #4
Who is your service provider?
Post the contents of /home/cyberpanel/error-logs.txt and /usr/local/lsws/logs/error.log here
an
antivirusadmin #5
I send you the log file in private message
we talk about Internet provider before :wink:
jo
josephgodwinke #6
Did you tamper with Openlitespeed? Most certainly OLS is not running
Post a screenshot of sudo service lsws status or ps -ef | grep litespeed
an
antivirusadmin #7
No , not at all
jo
josephgodwinke #8
Disable modsecurity and try again
an
antivirusadmin #10
I reboot the server
but nothing happen
an
antivirusadmin #11
Whats going on ?
after an houre its working now ! How ? Why ?
I want to find the problem to avoid stoping the webserver
I’m confused , I dont know what is the problem of this server and how it works…
an
antivirusadmin #13
Thanks , I will cheek theme
