Closed Create a website does not work
Hello @tomtom555 Happy you are here
Do you have any errors in main error log?
Did you try to upgrade your copy
Did you create a website for a domain localhost?
yes exactly
Add a proper domain for your website and try again it should work FREE domain names
I’m not hosting a website, so i dont need a domain, i just want to use the cyberpanel to manage my python bot, like database and others.
Is they anyhow i can create a website on the cyberpanell without adding a proper domain?
i also observed that i cannot connect to the database that i created on the localhost domain on a remote machine no mater how i try to edit settings.
could using the localhost domain the reason why a remote computer cannot connect to the database?
Honestly if you just using this for a bot and you dont need dns services, you do not need any panel for this. Why dont you run this on a clean server with only the necessary technologies to run the python bot. Install mariadb, python and setup your app. Add phpmyadmin or simply adminer with 2fa/otp for extra security. Add an IPS, a WAF etc.
This is not really an answer related to cyberpanel just my 2 cents
Yes ofcourse kindly use it you should not expect any errors
i still need cyber panel because i want to move my website to it in the future and i want to manage my database on phpmyadmin
I used it and it works find, thank you so much.
but i still cannot connect to my databse using a remote computer
Let’s follow the conversation here Cannot connect to database on a remote machine
