Problems with dovecot in latest 2.3.1 and 2.3.2 cp
Ma
Master3395 #1
Hello, in the latest version of CP, both dovecot setup for sieve fails.
I have been trying on clean OS installs.
I get the same error each time.
If I remove the sieve setup from the dovecot file, I can send and receive mail as usual and the ports open up again.
But right after adding Any sieve configs in, ports get closed.
I have tried every tutorial I can find and used my old dovecot file found on the link below.
Every setup shows the same error.
It seems that I am not the only person that has this problem with a clean OS with CP
ha
hamin #2
Svien plugin have some issues with the permission so when you have it. It will cause the issues.
Ma
Master3395 #3
Any workarounds, does give the whole sieve folder 777 work?
Nvm tried, but didn’t help.
Ma
Master3395 #4
Did you say that you got sieve working on 2.3.2 @usmannasir ?
