HELP me: Email not receiveing after setting up filtering spam in rainLoop
so
solopedro #1
I need urgent help with sieve
I setted up this carefully following all steps:
at the end of process: the fliters did not worked in individual accounts nor receiving emails in any ofthe server accounts.
I can send with no issues but i cannot received
The only difference Ihad with the settings was the first line:
Append “sieve” after ‘lmtp’ in protocols on the first line:
protocols = imap pop3 lmtp sieve
the difference was that i did not have lmtp on that line .
I have gone back correcting the settings to protocols = imap pop3 that is what I had at the beginning, ut still not working
I have centos 7
so
solopedro #2
this also i did to enble lmpt
edit /etc/dovecot/conf.d/20-lmtp.conf file to configure dovecot to enable the sieve plugin.
protocol lmtp {
Space separated list of plugins to load (default is global mail_plugins).
mail_plugins = $mail_plugins sieve
do not know what has gone wrong as I followed instructions as they are
Ni
NiiYankee #4
Also make sure that port 4190 is opened in your firewall
so
solopedro #5
this one not opened, how shall I do it?
so
solopedro #6
[root@fra ~]# netstat -tunlp | grep :4190
tcp 0 0 0.0.0.0:4190 0.0.0.0:* LISTEN 16312/dovecot
tcp6 0 0 :::4190 :::* LISTEN 16312/dovecot
udp 0 0 0.0.0.0:41901 0.0.0.0:* 2238/openlitespeed
so
solopedro #7
Thanks @NiiYankee
gone through all again opened port 4190, hostname and postmaster changed to mine
and firewall opened,
21 sieve tcp 0.0.0.0/0 4190
still no emails through
Ni
NiiYankee #8
There is a bud in the sieve script. This is the error I got also: sieve: Failed to access user’s personal storage (temporary failure)
Ni
NiiYankee #9
*bug
so
solopedro #10
how can I revert? I have some very angry clients
Ni
NiiYankee #11
Type your comment> @solopedro said:
Thanks @NiiYankee
Remove sieve and its configurations and your emails should start coming in again. Wait until there is a fix then try it again. After all, sieve with rainloop is beta.
Follow these steps:
  1. sudo yum remove dovecot-pigeonhole -y
  2. nano /etc/dovecot/dovecot.conf and remove the following: lmtp sieve in the first line then remove this: service auth {
    unix_listener auth-client {
    group = postfix
    mode = 0660
    user = postfix
    unix_listener auth-master {
    group = vmail
    mode = 0660
    user = vmail
    user = root
service managesieve-login {
inet_listener sieve {
port = 4190
service managesieve {
protocol sieve {
managesieve_max_line_length = 65536
managesieve_implementation_string = dovecot
log_path = /var/log/dovecot-sieve-errors.log
info_log_path = /var/log/dovecot-sieve.log
plugin {
sieve = ~/dovecot.sieve
sieve_global_path = /etc/dovecot/sieve/default.sieve
sieve_dir = ~/sieve
sieve_global_dir = /etc/dovecot/sieve/global/
lda_mailbox_autocreate = yes
lda_mailbox_autosubscribe = yes
protocol lda {
mail_plugins = $mail_plugins autocreate sieve quota
postmaster_address = postmaster@mydomain.com
hostname = mail.mydomain.com
auth_socket_path = /var/run/dovecot/auth-master
log_path = /var/log/dovecot-lda-errors.log
info_log_path = /var/log/dovecot-lda.log
protocol lmtp {
log_path = /var/log/dovecot-lmtp-errors.log
info_log_path = /var/log/dovecot-lmtp.log
  1. Save the dovecot.conf file
  2. Remove the folder at /etc/dovecot/sieve/global
  3. systemctl restart dovecot
  4. systemctl restart postfix
Your emails should start rolling in again
so
solopedro #12
Thanks a LOT @NiiYankee you are a star!!
All coming through now
Ni
NiiYankee #13
I found the solution for the sieve error on the forum: in the dovecot.conf file look for:
plugin {
sieve_dir = ~/sieve
and replace with this:
plugin {
sieve = /home/vmail/%d/%n/dovecot.sieve
sieve_dir = /home/vmail/%d/%n/sieve
so
solopedro #14
Won’t risk I followed the instructions exactly as they appear and did not work. So until they are correct prefer spam. Even if with the set to delete (1) in server does not work either
wh
whattheserver #15
Usually, this happens when the Spamassassin line in /etc/postfix/master.cf is wrong. Seen this on some installations.
If this is an existing installation then the below is how i setup that for all clients sieve to work by default to spam folder of Rainloop “INBOX.Junk E-mail”.
Install spamasassin via cyberpanel
backup configs:
cp /etc/dovecot/dovecot.conf /etc/dovecot/dovecot.conf-bak_$(date ‘+%Y-%m-%d_%H:%M:%S’);
cp /etc/postfix/master.cf /etc/postfix/master.cf-bak_$(date ‘+%Y-%m-%d_%H:%M:%S’);
cp /etc/postfix/main.cf /etc/postfix/main.cf-bak_$(date ‘+%Y-%m-%d_%H:%M:%S’);
cp /etc/dovecot/dovecot.conf /etc/dovecot/dovecot.conf-bak-sieve
cp /etc/postfix/master.cf /etc/postfix/master.cf-bak-sieve
cp /etc/postfix/main.cf /etc/postfix/main.cf-bak-sieve
Please NOTE:
TO reverse these modifications the below commands can be used.
cp /etc/dovecot/dovecot.conf-bak /etc/dovecot/dovecot.conf
cp /etc/postfix/master.cf-bak /etc/postfix/master.cf
cp /etc/postfix/main.cf-bak /etc/postfix/main.cf
service dovecot restart && service postfix restart;
service dovecot status && service postfix status;
Install required packages
Ubuntu
apt-get install -y dovecot-managesieved dovecot-sieve net-tools pflogsumm
Centos
yum install nano net-tools dovecot-pigeonhole postfix-perl-scripts -y
Empty the current config
copy in the new base one via nano. Replace “server.example.com” with your hostname and example.com with your domain name.
protocols = imap pop3 sieve
log_timestamp = "%Y-%m-%d %H:%M:%S "
mail_location = maildir:/home/vmail/%d/%n/Maildir
#mail_location = mdbox:/home/vmail/%d/%n/Mdbox
ssl_cert = <cert.pem
ssl_key = <key.pem
mail_plugins = zlib
mdbox_rotate_size = 2M
namespace {
type = private
separator = .
prefix = INBOX.
inbox = yes
service auth {
mode = 0600
user = vmail
unix_listener /var/spool/postfix/private/auth {
    mode = 0666
    user = postfix
    group = postfix
user = root
service auth-worker {
user = root
protocol lda {
log_path = /home/vmail/dovecot-deliver.log
postmaster_address = postmaster@example.com
mail_plugins = zlib
protocol pop3 {
pop3_uidl_format = %08Xu%08Xv
mail_plugins = $mail_plugins zlib
protocol imap {
mail_plugins = $mail_plugins zlib imap_zlib
passdb {
driver = sql
args = /etc/dovecot/dovecot-sql.conf.ext
userdb {
driver = sql
plugin {
zlib_save = gz
zlib_save_level = 6
port = 4190
protocol sieve {
plugin {
protocol lda {
mail_plugins = $mail_plugins sieve quota
hostname = server.example.com
protocol lmtp {
service stats {
unix_listener stats-reader {
user = vmail
group = vmail
mode = 0660
unix_listener stats-writer {
    user = vmail
    group = vmail
    mode = 0660
Create directories and permissions.
mkdir -p /etc/dovecot/sieve/global
touch /var/log/{dovecot-lda-errors.log,dovecot-lda.log}
touch /var/log/{dovecot-sieve-errors.log,dovecot-sieve.log}
touch /var/log/{dovecot-lmtp-errors.log,dovecot-lmtp.log}
touch /etc/dovecot/sieve/default.sieve
chown vmail: -R /etc/dovecot/sieve
chown vmail:mail /var/log/dovecot-*
nano /etc/dovecot/sieve/default.sieve
require “fileinto”;
if header :contains “X-Spam-Flag” “YES” {
fileinto “INBOX.Junk E-mail”;
Sieve the global spam filter
sievec /etc/dovecot/sieve/default.sieve
Restart and check services are up and then test.
service dovecot restart && service postfix restart && service spamassassin restart;
service dovecot status && service postfix status && service spamassassin status;
Start tailing logs:
tail -f /var/log/{maillog,mail.log,mail.err,syslog}
Sent your test Junk email with the below in the body of the email:
XJSC4JDBQADN1.NSBN32IDNENGTUBE-STANDARD-ANTI-UBE-TEST-EMAILC.34X
If you get the this message but are not seeing the email in the inbox and permissions and everything else is right:
delivered via spamassassin service)
Open config file and change the below line
nano /etc/postfix/master.cf
spamassassin unix - n n - - pipe flags=R user=spamd argv=/usr/bin/spamc -e /usr/sbin/sendmail -oi -f ${sender} ${recipient}
To:
spamassassin unix - n n - - pipe flags=DROhu user=vmail:vmail argv=/usr/bin/spamc -f -e /usr/libexec/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
If this is on Ubuntu the line might need to be using the Ubuntu lib path of /usr/lib/dovecot/deliver
spamassassin unix - n n - - pipe flags=DROhu user=vmail:vmail argv=/usr/bin/spamc -f -e /usr/lib/dovecot/deliver -f ${sender} -d ${user}@${nexthop}
Optional things that might be needed.
If you get this error:
spamc[7957]: connect to spamd on ::1 failed, retrying (#1 of 3): Connection refused
Disable IPv6:
Append below lines in /etc/sysctl.conf:
nano /etc/sysctl.conf
net.ipv6.conf.all.disable_ipv6 = 1
net.ipv6.conf.default.disable_ipv6 = 1
To make the settings affective, execute :
sysctl -p
Add missing spamd user:
groupadd spamd
useradd -g spamd -s /bin/false -d /var/log/spamassassin spamd
chown spamd:spamd /var/log/spamassassin
Create this file with the below value to ensure spamd listening on localhost
[root@srv ~]# cat /etc/mail/spamassassin/spamc.conf
-d 127.0.0.1
[root@srv ~]#
/etc/sysconfig/spamassassin
/etc/default/spamassassin
Resources:
wh
whattheserver #16
With existing data use this dovecot conf
New installs without existing email data.
For new installations, without any email data, I typically use this version. This uses a universal namespace for the names so it works better with Dovecot 2.3.x and email clients similar to how the cPanel and other ones do out of the box
Install spamasassin via cyberpanel for new installations without existing email data and files all spam into “INBOX.Junk”
backup configs:
and
Please NOTE:
Install the required packages
Ubuntu
Centos
copy in the new base one via nano. Replace server.example.com with your hostname and example.com with your domain name.
ssl_key = <key.pem
mail_plugins = zlib
namespace inbox {
type = private
separator = .
prefix = INBOX.
inbox = yes
mailbox Drafts {
special_use = \Drafts
auto = subscribe
mailbox Junk {
special_use = \Junk
auto = create
mailbox “Junk Mail” {
special_use = \Junk
auto = no
mailbox “Junk E-mail” {
special_use = \Junk
auto = no
mailbox spam {
special_use = \Junk
auto = no
mailbox Spam {
special_use = \Junk
auto = no
mailbox Trash {
special_use = \Trash
auto = subscribe
mailbox Sent {
special_use = \Sent
auto = subscribe
mailbox “Sent Mail” {
special_use = \Sent
auto = no
mailbox “Sent Messages” {
special_use = \Sent
auto = no
mailbox Archive {
special_use = \Archive
auto = create
mailbox “Archives” {
auto = no
service auth {
mode = 0600
user = vmail
    mode = 0666
    user = postfix
    group = postfix
user = root
user = root
protocol lda {
mail_plugins = zlib
protocol pop3 {
protocol imap {
passdb {
driver = sql
userdb {
driver = sql
plugin {
zlib_save = gz
zlib_save_level = 6
port = 4190
protocol sieve {
plugin {
protocol lda {
protocol lmtp {
service stats {
user = vmail
group = vmail
mode = 0660
    user = vmail
    group = vmail
    mode = 0660
require “fileinto”;
fileinto “INBOX.Junk”;
Start tailing logs:
To:
Disable IPv6:
To make the settings effective, execute :
sysctl -p
groupadd spamd
-d 127.0.0.1
[root@srv ~]#
Resources:
73
73Hn #17
I got Sieve up and working on Cyberpanel 2.1.1 Centos 7
What I noticed was that Cyberpanel’s dovecot version was 2.3 but the dovecot-pigeonhole available was not for that version.
I tried downgrading but that did not work since the configurations of the newer dovecot was different and caused “Authentication Failed” when logging in. So I had to go back up to version 2.3
These are my steps:
N.B. Step one will update dovecot to the latest version. Please make sure to keep track of your current version in order to rollback if configuration files clash.
What you are aiming to do is to get dovecot-pigeonhole the same version as your current setup.
First setup dovecot repository following this link:
Secondly, follow instructions in this link.
