ISSUE SSL FOR HOSTNAME not working
ne
neggs #1
Hi everyone,
I’ve performed a fresh install and successfully added my first website and domain. I’m now wanting to access cyberpanel via a domain and not the IP.
I’ve created a subdomain and updated the host SSL to this sub domain but the new URL just times out. The IP method of access still works, but not via the new sub domain. There were no error when creating anything, so I’m looking to be pointed in the right direct.
I followed these instructions, but no luck.
Thanks in advance!
us
usmannasir #2
If it times out then DNS should not be working yet, because even if CyberPanel fails to obtain Lets Encrypt SSL, self-signed SSL is issued.
And you should be able to access CyberPanel via your domain.
To be sure, please paste logs from CyberPanel main log file, which is at:
/serverstatus/cyberCPMainLogFile
ne
neggs #3
Many thanks!
It was a DNS issue (using cloudflare) which is now resolved.
in
insha #4
I have problem I can’t issue ssl for hostname I get SSL Issued. You can now access CyberPanel at: https://“domain”:8090
us
usmannasir #5
I have problem I can't issue ssl for hostname I get SSL Issued. You can now access CyberPanel at: https://"domain":8090
What do you see in CyberPanel main log file? Also mention the version.
in
insha #6
1.64. I can’t output log with that command I get not exist. What should I use for checking log file?
us
usmannasir #7
Logs can be seen at: /serverstatus/cyberCPMainLogFile
in
insha #8
It’s empty, can send you my root access in private?
us
usmannasir #9
Send via ticket.
in
insha #10
Ok
mu
muratduru #11
I have same problem.
When i want to add site with ssl support i see
“Cannot issue SSL. Error message: 0,283 Failed to obtain SSL for domain. [issueSSLForDomain]”
It’s my cyberCPMainLogFile
I solve my problem.
WN
WNO #13
I solve my problem.
hey, i am also facing the same problem how did you solved yours?
ma
mateusz2552 #14
Hello, I have a problem with renewing the certificate.
error:
Can not issue SSL. Error message: 0.283 Failed to obtain SSL for domain. [IssueSSLForDomain]
log
[11-22-13-Sat-Dec-2018] Failed to obtain SSL, issuing self-signed SSL for: wizbox.pl
[11-24-06-Sat-Dec-2018] Trying to obtain SSL for: wizbox.pl and: www.wizbox.pl
[11-24-15-Sat-Dec-2018] Failed to obtain SSL for: wizbox.pl and: www.wizbox.pl
[11-24-15-Sat-Dec-2018] Trying to obtain SSL for: wizbox.pl
[11-24-17-Sat-Dec-2018] Failed to obtain SSL, issuing self-signed SSL for: wizbox.pl
[11-25-01-Sat-Dec-2018] Trying to obtain SSL for: wizbox.pl and: www.wizbox.pl
[11-25-03-Sat-Dec-2018] Failed to obtain SSL for: wizbox.pl and: www.wizbox.pl
[11-25-03-Sat-Dec-2018] Trying to obtain SSL for: wizbox.pl
[11-25-05-Sat-Dec-2018] Failed to obtain SSL, issuing self-signed SSL for: wizbox.pl
[11-26-05-Sat-Dec-2018] Trying to obtain SSL for: wizbox.pl and: www.wizbox.pl
[11-26-08-Sat-Dec-2018] Failed to obtain SSL for: wizbox.pl and: www.wizbox.pl
[11-26-08-Sat-Dec-2018] Trying to obtain SSL for: wizbox.pl
[11-26-10-Sat-Dec-2018] Failed to obtain SSL, issuing self-signed SSL for: wizbox.pl
certbot - log
2018-12-02 18:35:05,308:DEBUG:certbot.main:certbot version: 0.21.1
2018-12-02 18:35:05,308:DEBUG:certbot.main:Arguments: [’-d’, ‘wizbox.pl’]
2018-12-02 18:35:05,308:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2018-12-02 18:35:05,324:DEBUG:certbot.log:Root logging level set at 20
2018-12-02 18:35:05,324:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2018-12-02 18:35:05,325:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/certbot”, line 11, in
load_entry_point(‘certbot==0.21.1’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 1240, in main
return config.func(config, plugins)
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 1142, in renew
renewal.handle_renewal_request(config)
File “/usr/lib/python2.7/site-packages/certbot/renewal.py”, line 375, in handle_renewal_request
raise errors.Error("Currently, the renew verb is capable of either "
Error: Currently, the renew verb is capable of either renewing all installed certificates that are due to be renewed or renewing a single certificate specified by its name. If you would like to renew specific certificates by their domains, use the certonly command instead. The renew verb may provide other options for selecting certificates to renew in the future.
ma
mateusz2552 #16
of course, I already had the version
Current Version
1.7
Build
4
Latest Version
1.7
Latest Build
4
the problem is still the same, some other ideas?
ma
mateusz2552 #18
How do I send a ticket?
Hi
Hifihedgehog #20
I’m now having this same issue with just one domain. “283 Failed to obtain SSL for domain. [issueSSLForDomain] [404]”
