cd /usr/local
wget https://cyberpanel.net/CyberPanel.1.8.6.tar.gz
tar -zxf CyberPanel.1.8.6.tar.gz
cp settings.py CyberCP/CyberCP/
rm upgrade.py
wget https://cyberpanel.net/upgrade.py
python upgrade.py
</blockquote>
<blockquote class="Quote" rel="rebnaque">hi look to see if you can use the zip file of the module called CLManager, go to "/ usr / local / CyberCP" then use the command python upgrade.py again https://drive.google.com/open?id=1v_NLRc2q-AM99z-unCyNgAWiEYLDvD7W</blockquote>
error upgrade;
File "upgrade.py", line 1654, in <module>
main()
File "upgrade.py", line 1650, in main
Upgrade.upgrade()
File "upgrade.py", line 1574, in upgrade
File "/usr/lib64/python2.7/site-packages/django/db/models/manager.py", line 85, in manager_method
File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 373, in get
num = len(clone)
File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 232, in __len__
self._fetch_all()
File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 1102, in _fetch_all
File "/usr/lib64/python2.7/site-packages/django/db/models/query.py", line 53, in __iter__
File "/usr/lib64/python2.7/site-packages/django/db/models/sql/compiler.py", line 863, in execute_sql
sql, params = self.as_sql()
File "/usr/lib64/python2.7/site-packages/django/db/models/sql/compiler.py", line 420, in as_sql
File "/usr/lib64/python2.7/site-packages/django/db/models/sql/compiler.py", line 373, in compile
File "/usr/lib64/python2.7/site-packages/django/db/models/sql/where.py", line 79, in as_sql
File "/usr/lib64/python2.7/site-packages/django/db/models/lookups.py", line 169, in as_sql
File "/usr/lib64/python2.7/site-packages/django/db/models/lookups.py", line 162, in process_lhs
File "/usr/lib64/python2.7/site-packages/django/db/models/fields/__init__.py", line 640, in db_type
File "/usr/lib64/python2.7/site-packages/django/utils/functional.py", line 35, in __get__
res = instance.__dict__[self.name] = self.func(instance)
File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/base.py", line 174, in data_types
File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/features.py", line 53, in supports_microsecond_precision
File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/base.py", line 385, in mysql_version
File "/usr/lib64/python2.7/contextlib.py", line 17, in __enter__
return self.gen.next()
File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 591, in temporary_connection
cursor = self.cursor()
File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 254, in cursor
return self._cursor()
File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 229, in _cursor
self.ensure_connection()
File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 213, in ensure_connection
self.connect()
File "/usr/lib64/python2.7/site-packages/django/db/utils.py", line 94, in __exit__
self.connect()
File "/usr/lib64/python2.7/site-packages/django/db/backends/base/base.py", line 189, in connect
File "/usr/lib64/python2.7/site-packages/django/db/backends/mysql/base.py", line 274, in get_new_connection
File "/usr/lib64/python2.7/site-packages/MySQLdb/__init__.py", line 81, in Connect
File "/usr/lib64/python2.7/site-packages/MySQLdb/connections.py", line 193, in __init__
super(Connection, self).__init__(*args, **kwargs2)
django.db.utils.OperationalError: (2003, 'Can\\'t connect to MySQL server on \\'127.0.0.1\\' (111 "Connection refused")')
