Yo,
It seems there is some sort of bug in 1.4.37. It has something to do with SSL, while im a noob and cant tell you what is it, I can tell you how to reproduce it.
Fresh install, CentOS 7 minimal, 1.4.37 was recently released this week, so its automatically downloaded and installed, continue as always, setup a site, WP, DNS etc.
Once site is up, i was spamming refresh with ‘inspect’ measuring load times, but on https, after ~10x quick F5 its just crashing/freezing for 10-30s with timed out error. Tried to look for some logs on the server, but as I said, im a noob. HTTP works perfectly fine.
Rolled back to 1.4.36 and this issue doesnt exist.
You mean yum remove openlitespeed and install ols-1.4.36?
Ok, its weird. Fresh install, https works flawlessly, the moment I turn css/js minifaction, all minified files are “404”, but it still works fine, no crashes. /Permission issue?
When I turn on HTTP2 PUSH in LS Plugin, its going south and it start crashing.
yum install pcre-devel openssl-devel expat-devel geoip-devel zlib-devel udns-devel git gcc gcc-c++ make autoconf glibc rcs cmake golang libtool libmaxminddb -y
wget https://openlitespeed.org/packages/openlitespeed-1.5.0rc4.tgz
tar xzvf openlitespeed-1.5.0rc4.tgz
cd openlitespeed-*
git clone https://boringssl.googlesource.com/boringssl
cd boringssl
mkdir build
cd build
cmake ..
make
cd ../..
./configure --prefix=/usr/local/lsws
make
make install
systemctl daemon-reload
systemctl restart lsws
This solve my issue.
And i had to enable “Use Server Index Files - Yes”, on General tab in Virtual hosts inside the server to fix 404 on permalinks, gg.
Maybe it will help someone, peace out ; ).
cd openlitespeed-*
cd boringssl
mkdir build
cd build
cmake ..
make
cd ../..
make
make install
It would definitely help someone, there are some issues with OpenSSL for now, will be sorted out soon.
wget https://openlitespeed.org/packages/openlitespeed-1.4.36.tgz
tar xzvf openlitespeed-1.4.36.tgz
cd openlitespeed-*
cd boringssl
mkdir build
cd build
cmake ..
make
cd ../..
make
make install
Guys, if someone has the same issue as me, use this one, not the one from the top of this topic. This will downgrade to 1.4.36, which is a safe spot i think, cheers!
Hey, I’m not sure if it apply to cyberpanel, but there is a limit of request for SSL from certbot, 5 per week per domain. Not sure if it stopped working or you hit the limit.
