Licensing Explained
Free Starter with CyberPanel
This gives you one top-level domain and unlimited sub-domains example:
- cyberpanel.net
- hi.cyberpanel.net
- docs.cyberpanel.net
- … and more!
You can not create something like cyberpersons.com, since this is a second top-level domain.
Add-ons
- LSCache Included for free.
- LiteMage available as add-on.
Site Owner with CyberPanel
This gives you 5 top level domains and unlimited sub-domains of these 5 top-level domains.
Add-ons
- LiteMage available as addon.
Enterprise License Manager
To manage your licenses navigate to https://<IP Address>:8090/serverstatus/litespeedStatus you will see something like:
License Status
If you click on License Status, it will only display your currently license and its expiration status.
Change License
You need to have your new license key in hand, before you use this option. This will open a box where you can enter your new key. Once you change your key you can again click License Status to see if your key is changed and new expiration date is reflected.
How to fix License Expired Redirect
If you have installed CyberPanel Enterprise and you are being redirected to License Expired Page. There are two major reasons for this:
- Your License has either expired or you have not correctly registered new key.
- License does not have CyberPanel Enterprise bundle. Licenses with CyberPanel bundle can be purchased from here. You can then change your license using License Manager.
Renew License
If your license is not expired you can skip this step, otherwise you need to open store and make sure you have renewed your license key.
Register New Key
Once you are sure that your key is not expired or you have already renewed it, open command line terminal and run
/usr/local/lsws/bin/lshttpd -r
/usr/local/lsws/bin/lswsctrl restart
And then restart LSCPD
systemctl restart lscpd
For more details you can visit
Containerization
If you are being redirected from the containerization page (:8090/container/) it means you have CyberPanel installed (with OpenLiteSpeed). This feature is only available with CyberPanel Ent (with LiteSpeed Enterprise Web server)
