Hi, for rainloop also?
Thx
Thx
Rainloop password is available using
cat /usr/local/CyberCP/public/rainloop.php
Hello ,
Can you pls talk about openlitespeed, i use dedicated server with good resources and i want modify openlitespeed without limit for can use all resources of my server , exactly the issue : lsapi possible deal lock
Thanks.
Please see the link that is already linked in the document above: OpenLiteSpeed vs. LiteSpeed Enterprise - LiteSpeed Technologies
@usmannasir
There was not necessary to remove it , just need more detail and explanation
something like this:
> CyberPanel Login URL
Visit: https://<your server ip>:8090
Panel username: admin
Panel password: ^i0lf1bi2AG^dlEt
**Open Litespeed web Console :**
Visit: https://<your server ip>:7080
WebAdmin console username: admin
WebAdmin console password: ^i0lf1bi2AG^dlEt
**Webmail Panel:**
Visit: https://<your server ip>:8090/rainloop/?admin
Rainloop Admin username: admin
Rainloop Admin password: ^i0lf1bi2AG^dlEt
actually i need that too
but some (more) user confusing about the different between Litespeed and cyberpanel admin login
That in openlitespeed ; i use that max connections for solve the problem of lsapi possible deal lock ,
i see the range of that is 1 to 2000 ,
My question are can use high number more then 2000 ,
and any modifications for openlitespeed not use the limit , i use dedicated server 8 core AMD so that is high resources i want use my resources without limit because i own my server
I am also having this same issue.
I’m using ubuntu 20.04 and all packages are up-to-date.
`root@admin82:~# sh <(curl https://cyberpanel.net/install.sh || wget -O - https://cyberpanel.net/install.sh)
100 1802 100 1802 0 0 5966 0 --:–:-- --:–:-- --:–:-- 5947
curl is already the newest version (7.68.0-1ubuntu2.11).
wget is already the newest version (1.20.3-1ubuntu2).
Initializing…
Fetching latest data from CyberPanel server…
This may take few seconds…
Unable to fetch Branch name…
Please try again in few moments, if this error still happens, please contact support
Would really appreciate some help - I think I have tried the process 20 times but every-time it fails
Thanks
Try ping https://cyberpanel.net/install.sh on SSH to see if your host blocking connection.
Thanks @Dreamer I tried ping but as you know you can only ping a domain i.e. cyberpanel.net or ip.
When I did ping cyberpanel.net I got the response back so its not blocked. There seems to be someother other issue as I can see that cyberpanel.sh get downloaded but it cannot find branch name.
I still haven’t been able to install cyberpanel. The VPS provider says that they are not blocking any ip or service. So I guess there is an issue with Cyberpanel. Can someone please assist me with this in resolving this issue of getting ‘Unable to fetch branch name…’ whilst installing cyberpanel.
Thank you
I’m using Ubunto 20.10, but when i install it says.
CyberPanel is supported on Ubuntu 18.04, Ubuntu 20.04, Ubuntu 20.10, CentOS 7.x, CentOS 8.x, CloudLinux 7.x, CloudLinux 8.x and AlmaLinux 8.x…
But when i run the comment it says - CyberPanel is supported on Ubuntu 18.04, Ubuntu 20.04, “Ubuntu 20.10”, CentOS 7.x, CentOS 8.x, CloudLinux 7.x, CloudLinux 8.x and AlmaLinux 8.x…
That’s might be typo what nobody noticed because it’s quite rare VPS providers have ubuntu 20.10 as option. Just go with 20.04 and you are fine.
Thanks for the update.
Ubuntu 20.10 has already stop getting updates too see here. So better stick with 20.04 which still get official updates.
How to install CyberPanel lightest version?
How can I remove unnecessary features to save server resources?
ready the step… when you asked to answer install all services (or something like that, just say N)
like what ?
