Your connection is not secure
I have just upgraded the server and cyberpanel. On testing a couple of websites I am seeing “Your connection is not secure”
I tried to manually Issue SSL (letsencrypt) for these sites, but all of them are saying the same.
The upgrade was from 1.7 to 1.8. Is there an issue I need to be aware of?
Nothing obvious in the error log
CyberPanel upgrade does not interfere with your SSL certificates.
Any hints how to fix this? Where to look
This certificate has expired (88 days ago) Reissue is not working and would it not normally renew automatically?
It should auto-renew. You can try to remove SSL directory and reissue SSL.
rm -rf /etc/letsencrypt/live/example.com
Thanks for the help. SSL files get updated now, but still errors.
ls -l harris-architect.com/
total 12
-rw-r–r-- 1 root root 1960 Feb 5 05:58 cert.pem
-rw-r–r-- 1 root root 3607 Feb 5 05:58 fullchain.pem
-rw------- 1 root root 1679 Feb 5 05:58 privkey.pem
When accessing the site is still showing Insecure Connection and not accessible.
SSL checker still claiming the cert has not been renewed or setup incorrectly
Error log
2019-02-05 06:11:04.689692 [ERROR] Invalid rewrite directive: SetEnv htaccessWorking true
2019-02-05 06:11:04.689696 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689700 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689704 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689708 [ERROR] Invalid rewrite directive: php_value upload_max_filesize 511M
2019-02-05 06:11:04.689712 [ERROR] Invalid rewrite directive: php_value post_max_size 511M
2019-02-05 06:11:04.689716 [ERROR] Invalid rewrite directive: php_value memory_limit 512M
2019-02-05 06:11:04.689726 [ERROR] Invalid rewrite directive: php_value mbstring.func_overload 0
2019-02-05 06:11:04.689731 [ERROR] Invalid rewrite directive: php_value default_charset ‘UTF-8’
2019-02-05 06:11:04.689735 [ERROR] Invalid rewrite directive: php_value output_buffering 0
2019-02-05 06:11:04.689739 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689743 [ERROR] Invalid rewrite directive: SetEnv htaccessWorking true
2019-02-05 06:11:04.689747 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689751 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689755 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689818 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689823 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689827 [ERROR] Invalid rewrite directive: AddType image/svg+xml svg svgz
2019-02-05 06:11:04.689831 [ERROR] Invalid rewrite directive: AddEncoding gzip svgz
2019-02-05 06:11:04.689835 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689839 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689843 [ERROR] Invalid rewrite directive: DirectoryIndex index.php index.html
2019-02-05 06:11:04.689847 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689851 [ERROR] Invalid rewrite directive: AddDefaultCharset utf-8
2019-02-05 06:11:04.689855 [ERROR] Invalid rewrite directive: Options -Indexes
2019-02-05 06:11:04.689860 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689864 [ERROR] Invalid rewrite directive: ModPagespeed Off
2019-02-05 06:11:04.689868 [INFO] Rewrite directive: bypassed.
2019-02-05 06:11:04.689872 [ERROR] Invalid rewrite directive: ErrorDocument 403 //
2019-02-05 06:11:04.689876 [ERROR] Invalid rewrite directive: ErrorDocument 404 //
2019-02-05 06:11:04.689881 [INFO] RewriteFile [.htaccess] parsed, return 0.
2019-02-05 06:11:04.689917 [INFO] [PlainConf] [virtualHostConfig:] start parsing file /usr/local/lsws/conf/vhosts/hostchestnut.com/vhost.conf
2019-02-05 06:11:04.706866 [INFO] [PlainConf] [virtualHostConfig:] RCS checkin config file /usr/local/lsws/conf/vhosts/hostchestnut.com/vhost.conf0 OK.
2019-02-05 06:11:04.707656 [INFO] [config:server:vhosts:vhost:hostchestnut.com] config conxtext /.filemanager.
2019-02-05 06:11:04.707779 [INFO] RewriteFile [/home/hostchestnut.com/public_html/.htaccess] parsed, return 0.
2019-02-05 06:11:04.707895 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/ccl.conf
2019-02-05 06:11:04.724565 [INFO] [PlainConf] [virtualHostTemplate:] RCS checkin config file /usr/local/lsws/conf/templates/ccl.conf0 OK.
2019-02-05 06:11:04.724725 [INFO] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2019-02-05 06:11:04.724782 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/phpsuexec.conf
2019-02-05 06:11:04.740571 [INFO] [PlainConf] [virtualHostTemplate:] RCS checkin config file /usr/local/lsws/conf/templates/phpsuexec.conf0 OK.
2019-02-05 06:11:04.740727 [INFO] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2019-02-05 06:11:04.740804 [INFO] [PlainConf] [virtualHostTemplate:] start parsing file /usr/local/lsws/conf/templates/rails.conf
2019-02-05 06:11:04.755383 [INFO] [PlainConf] [virtualHostTemplate:] RCS checkin config file /usr/local/lsws/conf/templates/rails.conf0 OK.
2019-02-05 06:11:04.755492 [INFO] [PlainConf] [context:/] rewrite [] add rules [rewritefile .htaccess]
2019-02-05 06:11:04.755539 [NOTICE] [ZConfManager] No VHosts added, do not send!
2019-02-05 06:11:04.756174 [NOTICE] [AutoRestarter] new child process with pid=14191 is forked!
2019-02-05 06:11:04.757020 [NOTICE] [child: 14191] Successfully change current user to nobody
2019-02-05 06:11:04.757065 [NOTICE] Child: 14191] Core dump is enabled.
2019-02-05 06:11:04.757124 [NOTICE] [Child: 14191] Setup swapping space…
2019-02-05 06:11:04.757236 [NOTICE] [Child: 14191] LiteSpeed/1.4.43 Open starts successfully!
Take a look at this guide How to set up Auto SSL Renew on CyberPanel! — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
Fantastic. That worked for all the sites. thank you! :slight_smile:
