Hello
I placed this code for my site and Error 404 was fixed. But then the problem
RewriteRule ^index\.php$ - [L]
RewriteRule . /index.php [L]
invalid application/octet-stream
But then the problem " invalid application/octet-stream "
download file when open site
What is your site address, and do you have anything else in the rewrite rules file?
https://studioninepro.com
Yes, I have other rules.
Did you add those rules manually? Try removing any extra rules first.
All rules are taken from the wp-rocket plugin
After removing rules you have to restart OpenLiteSpeed, can you print out your vHost Configuration for me?
I did the restart too. There is nothing wrong with this problem only when I transfer the database backup from the hostinger to cyberpanel
cat /usr/local/lsws/logs/error.log
Please create a ticket with us https://platform.cyberpanel.net, provide as much details as you can.
