My Wordpress site is not showing within Cyberpanel Wordpress List, however it is showing in list of websites. Why is my Wordpress site not manageable under the List Wordpress, deploy Wordpress, configure plugins, restore backups or remote backups area?
If you did not use the deploy Wordpress option, then your website would not be listed under Wordpress sites.
None of my wordpress sites show there since I manuallly set them up before this option was even there.
If you know how to make manual installation of WP or full migration:
Make a manual backup (file & data) of your current project in another location. Then deploy WP, let cyberpanel make the setup from backend. Once deployed, import your files & database.
Then click the menu database in Cyberpanel and change the db_name, db_user & passw to your configuration of wp-config.
After it, will let you make all you listed. Including incremental backup.
