I have an issue with the Wordpress Application Installer that has been occurring. I don’t see which or where the log file would be to get a clue as to the cause. I’m hoping someone has had the same issue and has a possible fix I could try.
Basically, I create a new website, successful. I go to manage website, go to install the Wordpress Application. Fill out the fields accordingly, and run the install.
I’m not entirely sure when this started happening exactly, but the issue still occurs after updating to the latest Cyberpanel version.
It acts as if it is doing the Wordpress Install, but the progress bar goes way to fast, and it misses a bunch of the steps I normally see when installing Wordpress on my other server running Cyberpanel.
It skips over for instance the ‘Downloading’ part, the ‘Installing Plugin’ etc etc.
The progress bar finishes and the message says “Installation Successful” but when I go to view the directory for the website the only file in there is the index.html.
I’ve tried deleting the contents of the public_html and running the installer again, same result.
Any suggestions is much appreciated!
Thanks
Provider:
Vultr
Virtualization Type:
KVM
System:
Centos 7.5
OLS or Enterprise?
OLS
official
no
no
Install LiteSpeed Memcached?
no
Install Memcached?
no
yes
Install Redis?
yes
