Hi guys,
I am new to CyberPanel. I recently installed it on an Amazon Instance and managed to create some websites inside of the server. I have also updated my domains with the server IP address as an A record.
However, when I try to access my domain address via the browser. It loads until time out error.
"The connection has timed out
An error occurred during a connection to www.mydomain.com. "
As a result I cannot get to install SSL Certificates via let’s encrypt. It installs rather the self-signed one which is basically useless.
This is what I have done so far
- Cyber Pannel is Updated to latest Version
- Acme is also updated to the lastest version
- Disabled Mod Security and firewall
- I ran this command: /root/.acme.sh/acme.sh --issue -d mydomain.xyz -d w ww.mydomain.xyz --cert-file
Resoponse: -bash: /root/.acme.sh/acme.sh: Permission denied - Tried going into file managers of these domains and Click Fix Permissions
- Rebooted the server
- Try add the certificate to the host domain
with no luck. I am basically stuck.
Domains are properly configured and are pointed to the server but just wont resolve. I believe this is why SSL cannot install successfully.
